  • syncrocrick Friend
    #173053
    Okay I feel like I have tried all the options in the module and I still can’t get it to display the articles (like in the demo).
    If I choose Show Tabs = “yes”, then I see the the categories under the “Editor’s Pick” bar. If I click on one of these, then I see the articles.
    Otherwise nothing, just the title.
    you can see here:
    http://www.expeditionportal.com/1.7
    any idea? thank you!
    syncrocrick Friend
    #434829
    I found the reason – there seems to be a conflict with the facebook slider extension that i added. If I turn it off it works okay.
    would someone have an idea why? I really would like to use it.
    Here’s the link:
    http://extensions.joomla.org/extensions/social-web/social-display/facebook-display/18779
    syncrocrick Friend
    #434835
    All right, I sort of fix it – there is an option in the extension to turn off “Show Jquery”
    By setting this “no”, it seems to have solved the situation. But I would still like to know why this is related.
This topic contains 3 replies, has 1 voice, and was last updated by  syncrocrick 12 years, 11 months ago.
