January 29, 2009 at 1:32 am #137612
I uploaded UVITA JA QUICKSTART and apparently everything works right. I just found a difficulty in the mod_jahighslide module. When I open the page, I do not show the images in small format, only shows me the zoomed image. ¿¿??
How can I fix this?
4170
4171
Thank you
cjmicro Friend
cjmicro
- June 2008
- 81 times in 10 posts
January 29, 2009 at 2:31 am #288742Do you have the folder set up on your site as indicated on the module parameters? If you set up a folder images/stories/highslide/thumbs you may have to create that folder and make it writeable. I would think that type of error would result in a parse error thought, not just the broken images.
That’s the only thing I can think of off hand.
Cheryl
1 user says Thank You to cjmicro for this useful post
January 29, 2009 at 3:02 am #288744The module and the plugin is configured as the images attached.
I understand that the image is a little reduced vision of the large picture. Or should have a smaller picture and put in another folder?.
If this is the same image enlarged and was in a wrong folder, you should not show it when I do not zoom.I installed the quickstart without changing anything, and everything works perfectly, I am surprised that this is just misconfigured.
Thanks again.
January 29, 2009 at 3:26 am #288746
I am not familiar with these forums and I think I have mistakenly given the choice of response. Well my answer by mistake. :((
Sorry, we do not know how to change this … :-[I’m still waiting for an urgent solution … I am totally lost with this problem and urges me to fix it.
Thanks for your patience.
cjmicro Friendcjmicro
- June 2008
January 29, 2009 at 10:56 am #288795I noticed when trying to set up the plugin my editor adds <a href” > to the url in the highslide, so i have to go in with the html editor and make sure that it isn’t messing up your syntax.
- June 2008
January 29, 2009 at 11:56 am #288800I have my plugin configured like this:
Plugin Parameters
outlineType= rounded-white
HighSlideCredits= Hide
loadingText = Loading...
Thumbnail Image width= 80
Auto resize image= No
Path Thumbnail Image= images/stories/slideshow/thumbs/ (i had to create this folder and make it writeable)Then in the article here is my highslide syntax:
{highslide type="slideshow-caption" url="http://www.wowgraphicdesigns.com/test/images/stories/slideshow/sl-02.jpg, http://www.wowgraphicdesigns.com/test/images/stories/slideshow/sl-03.jpg"}{/highslide}
You can see the example on my test site:
http://www.wowgraphicdesigns.com/test/index.php?option=com_content&view=article&id=55
(this page may not be working for long)Your problem might be having the Auto resize image to Yes (although that does seem to make sense it breaks mine too) I also do not even have the module enabled.
Hope it helps. Cheryl
January 31, 2009 at 11:45 am #289036The problem was that the quickstart does not create the folder:
/ images / resized / images / stories / gallery
If another user comes up with the same problem, just create this folder and give write permissions.
Thank you.
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by ipoblet 15 years, 8 months ago.
