  • Pankaj Sharma Moderator
    #1083567
    Can you share the URL here, so i can check it for you and give you style code for this?
    cloudt3 Friend
    #1083627
    Sure! [Here the URL]. Thanks
    • This reply was modified 6 years, 11 months ago by  cloudt3.
    #1083632
    Add below code in /css/custom.css file
    .latestnews {list-style:none}
    save and check,
    To add more style you use the same class and apply you custom style via custom.css file.
    cloudt3 Friend
    #1083642
    Thanks a lot!
This topic contains 4 replies, has 2 voices, and was last updated by  cloudt3 6 years, 12 months ago.
The topic ‘[SOLVED] Problem with module customization’ is closed to new replies.
