  • Tech-xml Friend
    #875862
    1 – The module is not displayed correctly 2 – The title is not displayed 3 – The module is not centralized
    1. Capturar
    Adam M Moderator
    #876506
    Hi @Tech-xml,
    It’s because the 3rd party module you used there doesn’t well coded (float container didn’t clear properly), try open file templates/ja_charity/css/template.css then add this code :
    .tjBs3:after {
         content: "";
         display: block;
         clear: both;
    Tech-xml Friend
    #876715
    Thanks for answering @adam M
    Decided to part; It remains to solve two problems:
    • Title of the module does not appear
    • The module is not centered
    Adam M Moderator
    #876867
    Hi @Tech-xml,
    1. To display the title, you can choose edit >>> switch to tab Advanced >>> in Module Style >>> choose XHTML.
    2. About centering the content, the module you use simply use masonry grid layout so it’s not possible to center it. I can help you modify this part but that means to drop the masonry style, please confirm.
    Tech-xml Friend
    #877186
    @adam M I authorize you to make the change, if possible I would also like to change the module title style as shown in the attached image.
    1. Capturar-1
    Adam M Moderator
    #878252
    Hi @Tech-xml,
    I made the change in your site and can see it was saved properly in backend but somehow the change doesn’t reflect in file templates/ja_charity/css/custom.css. Could you please recheck with your hosting vendor and temporary disable server cache ?
    Tech-xml Friend
    #878374
    @adam M The Cache Joomla Template and are disabled. May be some of the server cache, unfortunately I do not know how to turn this off.
    The change you made corrected the title of the module. Now he is centralized.
    Now I rpeciso he has this style:
    <Div class = "container">
    <H2 class = "mod-title text-center"> <small class = "first-word"> Recent </ small> Stories </ h2>
    </ Div>
    You can anviar me the changes I even doing here.
    Tech-xml Friend
    #879226
    @adam M I’m updating the posting if you are confused.
    Center Module and set the title for the theme default
    1. Capturar3
    Adam M Moderator
    #879796
    Hi @Tech-xml,
    Please try to clear the cache again and recheck, the code in custom.css file is as below :
    .tjBs3:after {
         content: "";
         display: block;
         clear: both;
    .moduletable > h3 {
        color: #3e3e3e;
        font-size: 35px;
        font-weight: 300;
        text-align: center;
        line-height: normal;
        max-width: 945px;
        margin: 50px auto;
        padding-bottom: 30px;
        position: relative;
        display: inline-block;
        padding-left: 56px;
        padding-right: 56px;
    .moduletable > h3:after {
      background: url("../images/ico/divide-side.png") no-repeat center bottom;
      height: 13px;
      position: absolute;
      left: 0;
      right: 0;
      bottom: -7px;
      content: "";
    .moduletable.bg-gray.jmoddiv.jmodinside {
      text-align: center;
    .tjBs3 .jgive_pin_item {
        position: static !important;
        margin: 0 10px;
    At the moment, it’s not possible to implement the title as you requested because it’s a bug in current version and I raised a bug report so our development team can check and fix it. The code I implemented for you is just a workaround so you might have to wait for a proper fix instead.
    Tech-xml Friend
    #879865
    Thanks @adam M for the excellent support. Problem solved
    Adam M Moderator
    #880500
    Hi @Tech-xml,
    Glad to be of assistance. I will keep the thread open for now and reply back when the bug report is solved so you can get notification about the update. If you still have any question, please don’t hesitate to let me know.
    Best regards,
    Adam.
    Tech-xml Friend
    #911380
    The module continues to have problems:
    1 – When the page loads the module is positioned to the left, only after a few seconds it centers.
    2 – Script error, the links contained in the module for responding (the mouse course focus does not work)
    1. Capturar
    Ninja Lead Moderator
    #912149
    Try to use this way to fix this bug
    Open templates/ja_charity/css/custom.css file and add new CSS style
    .moduletable > h3 {
        color: #3e3e3e;
        font-size: 35px;
        font-weight: 300;
        text-align: center;
        max-width: 945px;
        margin: 50px auto;
        position: relative;
        padding-left: 56px;
    to
    .moduletable > h3 {
        color: #3e3e3e;
        font-size: 35px;
        font-weight: 300;
        text-align: center;
        max-width: 945px;
        margin: 50px auto;
        position: relative;
        display: inherit;
        padding-left: 56px;
    .bg-gray {
        padding-bottom: 1px !important;
This topic contains 12 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 8 months ago.
