marco17 Friend
marco17
- January 2009
- 3 times in 2 posts
October 4, 2017 at 7:31 am #1065696Hi, we have a problem with the links in the sidebar (i attach image) when i put the mouse over they sisapear and then when i do scroll down the are showed in the wrong place.
The site is offline, i give you the acces to see the problem.Many thanks.
Marco
October 5, 2017 at 12:12 am #1065952Hi
Your site admin details are not working, please check and share working site details so I have a look on this issue.Regards
marco17 Friendmarco17
- January 2009
October 5, 2017 at 10:16 am #1066084This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
October 6, 2017 at 2:04 am #1066207Hi
Can you check it again?
Its showing fine at my end: http://prntscr.com/gtul4eRegards
- January 2009
October 6, 2017 at 9:26 am #1066356Hi,
I checked with diferents browers but it is showed wrong, i can see that you see it in horizontal instead in vertical….
Marco
October 6, 2017 at 9:42 am #1066365Hi
Can you try in your google chrome > incognito tab and share the device details and google chrome version if you have the same issue
I checked again and there is no issue.Regards
AuthorPostsViewing 6 posts - 1 through 6 (of 6 total)This topic contains 5 replies, has 2 voices, and was last updated by Pankaj Sharma 7 years, 1 month ago.
