  • stapel Friend
    #186139
    to log out the page is directed to this link and configuration of the module can not solve
    They can help me see this problem??
    http://www.nayagirls.com.br/index.php?option=com_virtuemart&view=user&layout=edit&Itemid=605
    tanks
    If i have correctly understood your question, you need to correct redirect url configuration of two modules
    1) Ja_Login – Joomlart module
    2) Login – Joomla core module ( showed in the page you posted above )
    Let me know if your problem is solved
    stapel Friend
    #487632
    no… my problem are in ja_login in the template ja_vintas
    Then i haven’t correctly understood your problem
    Could you be so kind to describe in more detailed way what is the problem you encountered ?
    stapel Friend
    #488983
    is done when user logout, the page is redirected to this link, how do I fix this??
    see the link after logout
    http://www.nayagirls.com.br/index.php?option=com_content&view=featured&Itemid=435
    already applied in the cofigurações login modules and the error is still
    Help-me please!!!
    This url http://www.nayagirls.com.br/index.ph…red&Itemid=435 is your Home page
    So if in your module is set logout redirect to Home then it’s correct – or you want the redirection to another page ?
    If you still having problems you can send me a PM with a temp super user account i will check your module configuration
    stapel Friend
    #488996
    ok … the modules are configured, but point to the URL that I indicate …
    Always giving this error
    Could you send me via Private Message a super user account for your admin page ?
    i will check your configuration and will try to solve this issue
    Hi Stapel
    I checked your ja_login module and redirects on login and logout are working fine
    I Solved your previous issue with login redirect pointing to a a menu alias creating a new menu item in a hidden menu
    Now your redirects are working fine
    stapel Friend
    #489029
    Thank you and glad for the help. This is fundamenrtal so everyone knows the quality of the work JoomlArt.
    Great service and great partnership with its customers
    Congratulations
    Wagner Stapelfeldt:)
This topic contains 10 replies, has 2 voices, and was last updated by  stapel 11 years, 7 months ago.
