January 23, 2009 at 10:51 am #137400
I’m using Labra template on Joomla 1.5.7 with VirtueMart 1.1.2.
I’m having following problem:
when browsing through VM products I have a custom html module positioned left, but it’s being shifted towards the bottom of the page.
You can see this here: http://test1.spletodrom.com.
It’s using custom module class suffix (div.module_vmcategories h6), but I had this problem before I created this suffix.
And it’s obviously problem with VM and Labra layout because modules in that position (left) on other pages are working ok.
I’ve tried to fix this in template.css, it seems that I’ve managed to fixed it, but when testing in different browsers and different screen resolutions it was a horror. :((
Thanks in advance for your help!
- 2008 times in 1700 posts
January 27, 2009 at 12:11 pm #288449Hi esedic,
I have tried to view your website but could not.
I saw an error: Network time out.Maybe this issue is from your network.
I will check your issue back again soon.
Please let me in detail as follows
+ The browser, which you have found this issue
+ The screen resolutionThanks.
February 4, 2009 at 12:21 pm #289500Hi!
I’m sorry for late answer but I haven’t resolved that issue yet.
It’s strange that you couldn’t view my website, maybe the problem is in flah loading on the frontpage (about 0,4mb large).
Anyway, could you please look again at the test1.spletodrom.com? On the frontpage you can see module onj the right side of the page (position right) which is positioned ok.
But if you go to http://test1.spletodrom.com/index.php?option=com_virtuemart&page=shop.browse&category_id=22&Itemid=82 you will see that other module isn’t positioned ok, it’s moved towards the bottom of the page.
I tried and tried with different changes to template CSS file but just couldn’t fix it.
February 5, 2009 at 4:30 am #289597Hi esedic,
I can see your website.
This cause is from your products. It is redundant div tag.
I have tried to go to your admin to check this cause but could not. I saw the notice: Login denied! Your account has either been blocked or you have not activated it yet.
Please check this issue again.
This topic contains 5 replies, has 2 voices, and was last updated by esedic 15 years, 11 months ago.
