June 8, 2012 at 11:29 am #177937
Hello, i’ve sone probleme with my website with ja_opal template.. The module on right position appare below the site….why?
Sherlock FriendSherlock
- 2478 times in 2162 posts
June 9, 2012 at 9:16 am #456758<em>@marketingbusiness 324331 wrote:</em><blockquote>Hello, i’ve sone probleme with my website with ja_opal template.. The module on right position appare below the site….why?</blockquote>
Hi marketingbusiness,
Mostly the problem is coming from your article contents those are being shown at your homepage.
Maybe you have messed up the contents (missing HTML open or close tag for example..) you should try to disable your articles one by one to find out the one holding the problemsJune 13, 2012 at 3:54 pm #457261Thank’s for thw answer but every time I try to post a new article I have the problem….you can see on my web site http://www.uglroma.it Thank’s so much.
June 13, 2012 at 8:34 pm #457288Please, I need a help. Thank’s!
June 14, 2012 at 6:40 am #457349Hi marketingbusiness,
Would be great if you can pm me your admin account and the FTP info as well, I shall check this out for you in details!
June 14, 2012 at 2:59 pm #457432Hello,
I don’t know how can I sand the information. I sand a private message to you. Thank’s so much.
June 15, 2012 at 3:12 am #457477Hi marketingbusiness,
I added some table tags into those file of templates/ja_opal/html/mod_janews/blog_item.php and templates/ja_opal/html/mod_janews/default_item.php, It helped to get rid of the problem.
you can check it again yourself.
June 15, 2012 at 7:51 am #457515Thank’s so much. But why was this probleme? We’ve not modified the code. Thank’s so much.
June 18, 2012 at 3:30 am #457724<em>@marketingbusiness 325513 wrote:</em><blockquote>Thank’s so much. But why was this probleme? We’ve not modified the code. Thank’s so much.</blockquote>
As I mentioned before the problem was coming from your contents, they probably was missing HTML tags (open or close tags), I add there table tags that wrapped your contents and it helped 🙂
This topic contains 9 replies, has 2 voices, and was last updated by Sherlock 12 years, 2 months ago.
