wertz Friend
wertz
- March 2011
June 26, 2014 at 3:40 pm #199181Hello,. i have a problem with displaying of Social module in a wrong, vertical position . So, want to keep their normal form / position. like in demo ja_mero site. ..se on http://newsite.marketweb.ro
Any suggestions?
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
June 26, 2014 at 3:53 pm #540293QUESTION:
When you installed your JA Mero template, did you do so utilizing the quickstart + sample data installation process?wertz Friendwertz
- March 2011
June 26, 2014 at 4:24 pm #540297hi, I just installed template on an old joomla root. without sample data.And then I have customized it. but I can say that this change to this social module, occurred after I made some changes to the main menu .(to be zoom, elastic, fade ans so on.). (then I tried to restore the settings.. exactly as they were but in hope the problem will be solved, but the problem remained in this social module) .. now my question is .. if main menu has some connection (to do) with social module..or not..? but this is my observation at this problem.otherwise i have no extra explanation?
TomC ModeratorTomC
- October 2014
June 26, 2014 at 4:40 pm #540300wertz Friendwertz
- March 2011
June 26, 2014 at 4:49 pm #540302unfortunately, I can’t do this because it is an upgraded version from joomla 1.5 to j. 3.
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
June 30, 2014 at 11:25 am #540626I have checked your site but didn’t see the social module there, could you please enable it so I can have a look?
acusticambiente Friendacusticambiente
- December 2012
September 29, 2014 at 6:45 pm #551035i have the same problem on my site (http://www.acusticambinte.it). any solution?
- May 2014
September 30, 2014 at 4:23 am #551071Hi @acusticambiente,
I couldn’t access your site, could you please recheck first ?
- December 2012
September 30, 2014 at 10:06 am #551140i’ve checked, site is on line
wertz Friendwertz
- March 2011
September 30, 2014 at 10:36 am #551147hi, a suggestion: check pictures of squares to see if have the same size or not?
- December 2012
September 30, 2014 at 10:52 am #551151all the pictures have the same size
- December 2012
September 30, 2014 at 1:45 pm #551180<em>@acusticambiente 447839 wrote:</em><blockquote>all the pictures have the same size</blockquote>
solved. i’ve changed the size of width in templates.ja_mero.less.typo.less.css (.social-wrap .btn-small)
AuthorPostsViewing 12 posts - 1 through 12 (of 12 total)This topic contains 12 replies, has 4 voices, and was last updated by acusticambiente 10 years, 2 months ago.
Problem with module Social module
