  • il88 Friend
    #142454
    Hello there, this is my first thread in your forum. I installed the ja nickel in my joomla. Everything works fine but the titles in modules appear in the loading and then dissapears both in IE 8 & Mozilla. The show title in the module properties is enabled.
    what’s going wrong?
    bennitos Friend
    #309895
    got a url where we can see this happening?
    il88 Friend
    #309897
    Here it is…
    http://www.iland-consulting.gr/
    try reload it the page, it is in greek.
    it is still under construction…
    houghtonpw Friend
    #309898
    Check to see if you have ‘Default Cufon’ set to ‘yes’ in your template manager.
    il88 Friend
    #309899
    You are absolute right! this was the problem! thx a lot!
    bennitos Friend
    #309900
    glad you got it sorted 🙂
This topic contains 6 replies, has 3 voices, and was last updated by  bennitos 15 years, 4 months ago.
