October 1, 2011 at 8:12 am #169165
Hello, I have a problem with template Ja-department because when I install my modules on my site, they work very well with my templates but they do not work with the template-ja ministries (though the module is enabled and I tried all positions).
Do you know where the problem may come from?
thank youpavit Moderatorpavit
October 1, 2011 at 8:33 am #415996Hi raffi3438
Sorry but i don’t understand what you mean with template Ja-department or template-ja ministries
Can you be more clear ?
October 1, 2011 at 8:38 am #415997I use ja minisite http://www.joomlart.com/joomla/templates/ja-minisite . My problem is that when i use ja ministe, none of my joomla modules displayed on my site but when I use any other template, all my modules jommla displayed on my site.
you know what the problem is?
October 1, 2011 at 6:57 pm #416059Hi
You are on localhost or your site is on web space ?
So you can give to me an admin account to your backend to analyze the issue
October 1, 2011 at 7:20 pm #416062Hi
You have forgotten to give me the password
October 1, 2011 at 7:23 pm #416064The new account don’t works
October 1, 2011 at 7:43 pm #416067Hi
I have tried to publish the Login module and the Ja_Slideshow module and both works fine
When you publish a module you must assign that module to a page ( Accueil in your case )
And the positions that you can choose must be of the Ja_Minisite template not Beez2 etc etc
October 1, 2011 at 7:54 pm #416072Thank you very much, yet it is what I did but anyway thank you
October 1, 2011 at 7:59 pm #416074but now I can not remove the module you added up, why?
As you get to add modules, can you please add the mod-janalitycs module of the screen? And is what you can disable the module you added up?
thank you very muchpavit Moderatorpavit
October 1, 2011 at 8:03 pm #416076Hi
I have disabled all modules try to clean your JaT3 cache
October 1, 2011 at 8:52 pm #416096For the mod-janalitycs you can choose a position a page and publish the module that’s all
October 1, 2011 at 8:53 pm #416097thank you and please can you add the mod-janalitycs module?
October 1, 2011 at 8:56 pm #416098In wich position you want the module published ?
October 2, 2011 at 7:03 am #416179Please, can you put it in the bottom of the page?
thank you -
This topic contains 20 replies, has 2 voices, and was last updated by raffi3438 12 years, 11 months ago.
