  • filomena78 Friend
    #154222
    I published some modules (mod_virtuemart_featureprod and facebook fanbox) only on the homepage but when I go to the cart and click on checkout it shows them again and shows too much below the box to purchase: what does it may depends and how can I fix? Thanks 🙂
    1. print
    You must create a menu item to display on the main menu or other menu for this module because joomla will base on the value of Item ID to display modules. If the component does not relate to any menu, all links of this component do not have “ItemId” parameter for joomla to show modules at the home page.
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 2 months ago.
