Viewing 15 posts - 1 through 15 (of 53 total)
  • Pankaj Sharma Moderator
    #833744
    there are two menu items
    1. Home IT(default menu on site)
    2. home (separate menu item)
      Please separet the default menu it a new menu and IT menu in other . do not add both under same menu .
      Also assign the module for both menu .
      Note : AT this time the default menu is home here > http://prntscr.com/9jpbkk
      that have no module assigned on it . so its blank .
      Enable language filter , and assign the menu to each other via Menu assignment tab in menu options .
    librandi Friend
    #833832
    thank you very much, I do it, but it doesn,t work. Can you help me please because I tryed for 3 days
    #833837
    Could u provide info what exactly you needed ?
    Because the default Homepage is not showing any content as there is nothing assigned to it .
    and there is no language filter on site .
    librandi Friend
    #833863
    the general home is special blank content with 2 modules, the language filter is active, but I see this error The requested URL /it/ was not found on this server.
    #833869
    Your site may have resirections as i can see its not using index.php in url and giving error no input file specified .
    please remove the redirection or turn off SEF from global options and check , its problem from htaccess and site urls .
    librandi Friend
    #833880
    I had cancelled .htaccess and I use htaccess.txt, I removed option self url in global configuration but it not work, please help me because I need, you can do everything on my site please
    librandi Friend
    #833917
    is it possible the problem in in ja mono? If I change template in home it works
    #833924
    Hi Your site giving error no input file specified , this error may due to hosting side . U can try to fix it with way as i checked this is a know issue here Global configuration -> SEO Settings. Switch off Search Friendly URLs. Now all menu links should work fine. Site will work once this issue fixed on SEF OFF .
    Also try to use special page blank content only for one template , it may conflict use same layout type in both templates .
    librandi Friend
    #833963
    Dear Pankaj Sharma , first of all thank you for the answers,
    I went crazy for two days , the problem is only in ja mono , in fact I changed the template of the home and everything works fine , but if I choose ja mono in the home out the error . The problem is that I need the ja mono home.
    librandi Friend
    #834088
    I change blank page with Featured Articles in every menu (in local) but it’e the some help me please
    librandi Friend
    #834131
    I do another joomla istallation on pirriprova.it ( account is same) with 6 language and all work very well, let try please, if you chance template (mono) it stop to work, for this reason I think the problem is in ja mono.
    #834453
    Hi librandi
    Apology for the issue , it seems the problem is from template , i am sending this issue to our senior level department for further investigation and fix , kindly edit your first post and also submit FTP details in it.
    Stay tuned.
    librandi Friend
    #834642
    thank you, I do it now
    bye
    Ninja Lead Moderator
    #834721
    @librandi: I try to check but the URL you provided doesn’t work, kindly re-check.
    I am not sure what did you configuration the multi-language on your site, but you can check the steps to setup multilingual site from here
    Besides that, you can have a look our demo here, you will see it’s working fine with multi-language.
    1. Screen-Shot-2015-12-30-at-16.20.51
    librandi Friend
    #834804
This topic contains 53 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 9 months ago.
The topic ‘Problem with multilanguage’ is closed to new replies.
