Viewing 15 posts - 16 through 30 (of 53 total)
  • Ninja Lead Moderator
    #834805
    I got the problem when I login with username/password of you provided, please check it again
    librandi Friend
    #834843
    librandi Friend
    #834844
    librandi Friend
    #834871
    If you want you can change administrator language in english, thank you very much
    #835808
    @librandi: I got the problem from front-end of your site. I login it with provided username / password and it got this problem
    This webpage has a redirect loop
    ERR_TOO_MANY_REDIRECTS
    You have to fix this bug first, I will help you to check other bugs on your site.
    librandi Friend
    #835848
    You don’t entry in back end of joomla with admin/nizzardo?
    #835883
    I tried to check that bug from front-end of your site and still got this bug: http://prntscr.com/9kkpsk you can check it again.
    librandi Friend
    #835901
    but this is the problem, now the template of all home is mono, if you entry in back end and change it with ja hotel all works well. This is my problem for begin the ticket 🙂
    librandi Friend
    #836078
    in pirripirri.it I had cloned gfimmobiliarecalabria.com whit ja hotel and it works well, now let try to change ja hotel with ja mono and you see the problem. thanks
    librandi Friend
    #838044
    please, you can solve the problem? I cloned the site, and it works well, but if I change template (from hotel to mono), it is no visible.
    Pankaj Sharma Moderator
    #838084
    i spent a lot of time on site , and checked redirect loop , please disable your redirection from .htaccesss and solve no input file specified issue and redirect loop.
    As JA Hotel template also showing the redirect loop on site> http://prntscr.com/9lw214
    http://prntscr.com/9lw2lh
    I also tried to change homepage into a category blog and use default Joomla template , not working too .
    please check and remove the redirection and fix the redirection loop issue without solving this issue its hard to assume the problem .
    librandi Friend
    #838178
    please, can you see pirriprova.it, it works fine. Now, can you cange template in it, if you cange hotel with mono it stop to work.
    librandi Friend
    #838214
    Hi, I am very sorry for the trouble I have given you, but I’m sure the problem is ja-mono for these reasons:
    1) I loaded in local the quick start of mono and it works, if I add another language it no works.
    2) in the site gfimmobiliarecalabria.com I changed the template of 6 home and work, so the file htaccess works well, why if I change with mono does not work? everything is the same, just change the template.
    1. Cattura
    librandi Friend
    #838401
    librandi Friend
    #839026
    do you fixed the bug in template?
This topic contains 53 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 9 months ago.
The topic ‘Problem with multilanguage’ is closed to new replies.
