librandi Friend
librandi
- February 2012
- 2 times in 2 posts
January 6, 2016 at 7:52 am #839790Can I know something about?
- November 2014
- 3854 times in 3563 posts
January 6, 2016 at 8:16 am #839808@librandi: Apologies for this late response, somehow I need time to check the problem on your site and hope my explain below will help you to understand
You could not run both JA Mono and JA Hotel templates on your site and only want to run one of them.
I am guiding you to work JA Mono template with multi-language
Create the menu item, template style and assign the menu item with each language
- Create general menu (homepage) to work with all language and the homepage with each language.
You will have a site to work with multi-language on your site.
librandi Friendlibrandi
- February 2012
January 6, 2016 at 8:25 am #839817Probably my english is bad, http://www.pirriprova.it is the quick start of mono, without ja hotel, and I had done :
It isen’t work. Let try pleasePankaj Sharma ModeratorPankaj Sharma
January 6, 2016 at 10:24 am #840003Hi
Please follow the instruction given by Ninja Lead here
Or only install quickstart with sample data and let me know i will help u to set the multi language . I checked the package on my local system and its working fine for me Here> http://prntscr.com/9mpknb
Also do not add any redirection in the .htaccess file .librandi Friendlibrandi
- February 2012
January 6, 2016 at 3:29 pm #840255Excuse me if I repeat , I have done everything , I work with your templates and extension from 3 years , so I think I did all right . Please can you see where is the error in pirriprova.it , there is only the simple quick of ja mono. Thank you.
ps : if I must pay please tell me .Pankaj Sharma ModeratorPankaj Sharma
January 7, 2016 at 2:44 am #840579Dear Sir
I checked package on my local system and its working fine with the Multi language as u can see in my screenshot . This is reason i asked the details , kindly only install quickstart with sample data and provide admin details to me so i will help u to set the multi language in that site . Without configure the package on your server its hard for me to check the problem is in package on server side (demo site working with multi language and and localhost its also work for me) .
Thanks in advance for your understanding in this case .librandi Friendlibrandi
- February 2012
January 7, 2016 at 4:59 am #840658This reply has been marked as private.librandi Friendlibrandi
- February 2012
January 7, 2016 at 1:05 pm #841002Hi,
I see you istall italian language, but it doesn’t work.Pankaj Sharma ModeratorPankaj Sharma
January 8, 2016 at 3:26 am #841510Hi
I tested same setting on your site but got same error , its very strange bug for us too , I sent the bug report to development for further investigation and fix this bug . You can track the bug report Here
Stay tune .
I appreciate your patience in this case .
Thankslibrandi Friendlibrandi
- February 2012
January 15, 2016 at 6:23 pm #848948Hi Pankaj Sharma,
how I know somethig? another week was passed and I can’t see notice, can you help me because I finished the site but I can’t publish it
thank for your helpNinja Lead ModeratorNinja Lead
- November 2014
January 18, 2016 at 7:05 am #851339This issue is reported to the development team, give them a bit more times to fix this.
- February 2012
January 23, 2016 at 9:28 am #865947This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
January 25, 2016 at 4:28 am #867400In this case, our dev will involve checking the problem directly on your site, you can give me the URL of your site, admin login and FTP account via Set as private reply. We will help you out soon.
- February 2012
January 25, 2016 at 7:18 am #867490This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
January 25, 2016 at 9:12 am #867589Our dev fixed the problem directly on your site because you’re using old version on your site. You should upgrade it to the latest version.
Besides that, we have released a new version, pls take a backup of your site before upgrading it.
This topic contains 53 replies, has 3 voices, and was last updated by Ninja Lead 8 years, 9 months ago.
The topic ‘Problem with multilanguage’ is closed to new replies.
