Viewing 8 posts - 46 through 53 (of 53 total)
  • librandi Friend
    #870167
    thanks, Now the language in old version works very wellhold , but the gallery style 2 in home and in "affitti" are disappared can you resolve the conflict?
    thank you
    Ninja Lead Moderator
    #870337
    If possible, send me the link and screenshot highlighting the problem you’re mentioning, I will check it for you.
    librandi Friend
    #870446
    I attach the screenshoot of original site befor you correct the language.
    1. Cattura-5
    #871072
    Because Affitti module assigned to show only under italiano language, see the screenshot. Now, you can the URL of your site with /it/ language, you will see it’s working fine.
    1. Screen-Shot-2016-01-29-at-09.58.42
    librandi Friend
    #871290
    Sorry I don’t understead.
    I would ask you if is possible to see the homa page like screen shoot with ….. /it?
    #871352
    It’s very hard for me. Because I didn’t see anything the configuration of the module on your site before to fix the problem multi-language on your site.
    In this case, you can create the new module and configure it as /it/ language on your site and apply it to other languages on your site.
    librandi Friend
    #871451
    #873012
    I only fixed the problem on your site from templates/ja_mono/templateHook.php file and didn’t change anything the configuration on your site
    You can download JA Mono Template here and copy that file to fix the problem of multi-language on the copy of your site.
This topic contains 53 replies, has 3 voices, and was last updated by  Ninja Lead 8 years, 9 months ago.
The topic ‘Problem with multilanguage’ is closed to new replies.
