dragonlord Friend
dragonlord
- January 2008
- 15 times in 1 posts
September 24, 2008 at 9:35 pm #133702With a article with one page there is no problem
But if there are more than one page the right modul position moves to the bottom
EDIT
I have found out that the moving of the right module position is only on the first page of the pages. F.E. if an article has 5 pages the wrong right module position exists only on page 1/5. The pages 2/5, 3/5, 4/5 and 5/5 are right.
2Patrick Friend2Patrick
- July 2008
- 11 times in 1 posts
September 24, 2008 at 11:55 pm #272156Yes..I tried exactly what dragon Lord did and I have the same problem
Joomart – another bug does needs fixing immediately!
Sherlock FriendSherlock
- 2478 times in 2162 posts
September 25, 2008 at 2:06 am #272173Can you give us your live URL, any screenshot or more details of the problem will be helpful
dragonlord Frienddragonlord
- January 2008
September 25, 2008 at 6:31 am #272196@ nguoiabcd
Unfortunately i can not give an live URL because i am testing JA Rutile on my virtual Server (Xampp) at the moment.
I have attached the original source code of the multilateral article. Copy it easily in the editor of your JA Rutile (Source Code View) and publish the article, then you can see the error.
- July 2008
September 26, 2008 at 1:29 pm #272469Hi Nguiabcd
Any update on this bug ? Has it been solved ?October 31, 2008 at 2:19 am #277578nguoiabcd,
I have similar problem, except that right module goes to left and left goes under ja_news.
See http://www.remela.com/?tp=1It seems to show up after the 5th article in a category is published. As soon as it is unpublished, it goes away. I cut my 5th article to just 2 lines of text w/o graphics and still the problem persists.
I have to say that most of the templates I have tried have some such problem or the other and it is annoying. It seems like you don’t test sufficiently before release.
I am using J1.5.7, CB 1.2 RC3, UDDEIM 1.4 .
Plugins : UddeIM (quick message) and inbox
No template modifications, except for defining _UE_TABINBOX in english.phpSherlock FriendSherlock
October 31, 2008 at 6:48 am #277597nguoiabcd,
I had copied plain text into tinymce editor from vi all along. Seems like the html got created incorrectly under some conditions – lot of empty unncesssary divs.
When I removed all those empty divs, problem went away. Could have been a missing /div there. Thanks.:)
I am guessing the source might be my Chrome browser or tinymce.
Wonder if dragonlord’s and 2Patrick’s problem is same or if that is a real bug !
November 24, 2008 at 6:33 pm #280163nguoiabcd,
Ok, this is a new one, though basically same issue.
Go to http://www.remela.com . Click on ‘Buyer Agent SF Bay Area’ in the middle top .
I am using JReviews 2.0 with 2 listings published.
You will see the module positions are screwed up after clicking on above link.
This time there is no /div or similar issue. The article html is very simple.Interestingly, if I unpublish one of them, the problem goes away.
It used to happen even with just 1 published listing. But that went away when I removed the <p> tags in the html and made it simple text. But that solution is cumbersome as I cannot keep editing everybody’s listing all the time.
So, why does this keep happening ? I get the feeling there is some issue beyond the html tags.
Help greatly appreciated.
November 27, 2008 at 10:22 am #280496Hi
I saw that you using Rockettheme template :rt_versatility4_j15
Please kindly contact their developer to supportNovember 28, 2008 at 2:58 am #280575Giving a response after 4 days and that too one which is not helpful, is not acceptable. I have paid for something that does not work !
To add to my problems my ability to put new posts was disabled at that time. No response from Hung Dinh, despite PM’ing him. So I tried rockettheme.
.I used their template and my problem was solved. -
This topic contains 11 replies, has 4 voices, and was last updated by soma9 16 years ago.
