canadareic Friend
canadareic
- November 2010
July 25, 2017 at 7:28 pm #1051520We are using a multisites component jms2win and we are having chalenges with the headers and footers on our websites
while modifying the header or footer of one webisite and publishing it the same header and footer is published on another website
my question is, where is this information stored on the database or the physical files please let us know where to change or modify
the informationSaguaros ModeratorSaguaros
July 26, 2017 at 7:13 am #1051666Hi,
In JA Builder, the header / footer block in header / footer part will be used in all pages. If you want to use different header / footer for different pages, you can edit a page >> add header/footer block into the content part instead of header part.
canadareic Friendcanadareic
- November 2010
July 26, 2017 at 4:37 pm #1051792Hello Did you have chance to read my question before answering ?
Pls read carefully
the informationWhat I have in mind
1) we know how to put headers in the content and that is not the answer to our questionour question is
is header information is stored in the database ? If yes what table ?
or
if information is stored in template folder which file is responsible for it ?Saguaros ModeratorSaguaros
July 31, 2017 at 2:36 am #1052529Hi,
When you add a header block, it will be pulled from our tool to your site.
Could you share the credentials of your site and how you want to achieve? I will check for you.
- November 2010
August 3, 2017 at 4:37 pm #1053587This reply has been marked as private.Saguaros ModeratorSaguaros
August 4, 2017 at 8:24 am #1053733I just check above sites but they have different headers now.
Could you details steps of which page should I make change to replicate issue?
- November 2010
August 17, 2017 at 1:50 am #1056881pls kindly have look on the page
http://calgaryrenttobuy.com/about-us before editing and while editing2 different pages , even different websites ( yes cache cleared )
August 18, 2017 at 4:42 am #1057098Hi,
Could you check the firewall access info again? as it doesn’t work now.
- November 2010
August 18, 2017 at 5:18 am #1057106This reply has been marked as private.Saguaros ModeratorSaguaros
August 20, 2017 at 2:01 pm #1057370This reply has been marked as private.canadareic Friendcanadareic
- November 2010
August 20, 2017 at 11:44 pm #1057488if you could just read same post ( private message )
August 3, 2017 at 4:37 pmyou will have all answers ?
or do you expect me to post credentials on every my reply?canadareic Friendcanadareic
- November 2010
August 20, 2017 at 11:45 pm #1057489This reply has been marked as private.canadareic Friendcanadareic
- November 2010
August 21, 2017 at 12:03 am #1057493pls also look at
http://goldenagersbuyrealestate.com/there is header from http://www.calgaryrenttobuy.com
- November 2010
August 23, 2017 at 9:37 pm #1058237Is there any way to accelerate support reply ?
We are under pressure to have this solved asap ?
We started ticket month Ago.I beg you to solve this issue ASAP
- November 2010
August 25, 2017 at 12:52 am #1058496Just wondering are you asking me to pay extra to get any kind of support ?
This topic contains 17 replies, has 2 voices, and was last updated by Saguaros 7 years, 3 months ago.
