August 30, 2014 at 11:25 am #200926
Hi there, I recently installed Joomla 3.3.3. to markvis.net and uploaded Ja Sugite to it. Shortly after I started to develope my site as in the Demo for Ja Sugite, the front end stopped showing up. An error message came on the screen as such:
The first couple of times this happened I just reinstalled joomla to the server. I tried using a lower version but always the same. I do not know exactly when this happens during development, but the first time I was well in to developing the structure of the site when it crashed.
I did previously redirect my old vebsite: http://vefgerd.markvis.is to http://markvis.net through Alias on my server. I did unplug it the first time this occur but maybe it messed with some of my core files, donĀ“t know.
I have contacted the expert support at godaddy.com and they told me that the problem is joomla related.
I have tried about everything that comes to my mind, reinstalling all index.php files, reinstall my quickstart files with no luck. This is especially frustrating since I previously was going to use Ja_Puresite for my website but was told by joomlart expert that I had to roll back joomla from 3.3.3. to 3.2.1 so I decidet to change the template.
I need help :((
best
ekaup
August 30, 2014 at 4:10 pm #547724Hello ekup
did you added any url redirection code in your .htaccess file ??
or using any url redirecting extension ? seems like issue in url routing .
Please check your .htaccess file and let me knowAugust 30, 2014 at 4:16 pm #547726Hi Pankajsharma, I did not add anything. I just installed Ja Sugite, started to modify the front end modules and this happened. I modified T3 frames to show my modules. The first time this happened I had almost finished the front page.
August 30, 2014 at 4:21 pm #547727Hello i found the problem on your site .
your site has only one menu >>Home
that is single article menu type . but you don`t have any article on your site >>http://prntscr.com/4i04xn
so site is not loading because it have not found any article and there will be loop.
the article you selected in the menu >>Home is >>Getting started , >>>http://prntscr.com/4i06ib
i found it in trashed .
>>>http://prntscr.com/4i066vPlease add article and assign it your homepage so that your site will start working .
Hope it helpsAugust 30, 2014 at 7:45 pm #547735Thanks so much Pankajsharma, this works. I should have figured it out. In my mind the problem was much more complicated. Thanks agin.:)
ekaupAuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 2 voices, and was last updated by ekaup 10 years, 1 month ago.
Problem with my Ja Sugite when I try to insert content and build modules
