  • john patrikiadis Friend
    #1090528
    I have uploaded my site to temp server and I get an error which the component’s developer told me it is something that you need to check.
    Here is what they say
    Hi John,
    The issue is coming from your JoomlArt template. As you can see, it works in Protostar:
    http://arionsoftware.epizy.com/download-commerce?template=protostar
    We’ve isolated the problem to their T3 plugin. Specifically the layouts folder in it. If you take:
    /plugins/system/t3/base-bs3/html/layouts/joomla
    and rename it to:
    /plugins/system/t3/base-bs3/html/layouts/joomla_disabled
    The site works. Could you report the issue to JoomlArt’s developers?
    Let us know if you have any questions and we’ll be glad to answer.
    Kind regards,
    The problem is at the http://arionsoftware.epizy.com/commerce page if you choose read more at the right hand side http://prntscr.com/ib910p you see the problem
    the site is in Greek and you may not be able to understand so if you have any problem let me know.
    Hi John,
    I got your point, could you share the FTP account also? I will investigate further.
    #1090732
    http://prntscr.com/ibpint
    password the same
    #1090986
    use Patrikiadis1967
    I edited this file: /plugins/system/t3/base-bs3/html/layouts/joomla/edit/params.php
    by changing:
    $form      = $displayData['form'];
    $fieldSets =  $displayData['fieldsets'];
    $displayData = $displayData['params'];
    to:
    $form = $displayData->getForm();
    $fieldSets = $form->getFieldsets('params');
    if (empty($fieldSets))
        $fieldSets = $form->getFieldsets('attribs');
    Kindly check.
    #1091003
    why did this happen? I also have the http://www.arion-software.co.uk site which is using the same component and i don;t have this problem
    Maybe it’s using old version of Joomla or T3 framework? This is an issue of T3 and it’s updated to T3 framework plugina nd will be released soon.
This topic contains 7 replies, has 2 voices, and was last updated by  Saguaros 6 years, 10 months ago.
