harsa Friend
harsa
- August 2008
December 8, 2011 at 6:58 am #428617<em>@jooservices 287817 wrote:</em><blockquote>Hi
Are you upgraded your module via … JA Extensions Manger or sth like that ?By somehow your upgraded version have bit trouble. And that’s make trouble.
Thank you,</blockquote>
somehow, before i upgraded, i did reinstall the same version but still having error.. and it seems that you have change it back to the previous one.. but now, after you have made the correction, when i try to change the text, i have the same problem.. the description was gone..how to correct that one.. it seems that it is not because of the upgrading the module.. its something else..
btw, can you fix the current error?
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
December 8, 2011 at 8:59 am #428633Hi
You can simply replace it by the version included in quickstart of this template.
And moment don’t upgrade this module .harsa Friendharsa
- August 2008
December 8, 2011 at 9:28 am #428639<em>@jooservices 287842 wrote:</em><blockquote>Hi
And moment don’t upgrade this module .</blockquote>hi,
i’ve replace the error module with a new one taken from the quickstart folder.. and everything is back to normal.. BUT when i just add a dot (.) in the description in the module (at the right) and i save the module.. when preview it, the description all gone.. i think there is something wrong somewhere..and now i have to ftp again the module.. after this, can you do me a favour? can you try to modify a bit on the description and see whether its ok or not..
thanks a zillion
harsa Friendharsa
- August 2008
December 8, 2011 at 9:40 am #428641hi,
just to make it clear, my initial attention is to modify the wording in below pic.but after i modified the text/description in the module, and i save it, when i preview, my website become like below pic
the error still not settled eventhough i have reinstall the module again n again.. i cannot even change a (.) in the description..
appreciate any help from the expert..
jooservices Friend
jooservices
- October 2014
December 8, 2011 at 10:16 am #428652Please give your correct description you want to use than i can try to do.
Thank youharsa Friendharsa
- August 2008
December 8, 2011 at 10:43 am #428662try this one for the first picture..
“We receive order for wedding and engagement cakes. We can customize the design according to your needs”
harsa Friendharsa
- August 2008
December 8, 2011 at 11:33 am #428673i’ve check, you can change it.. but why i can’t?? is there something that i need to do?
please tell me how did you change it? is it my computer or what?jooservices Friendjooservices
- October 2014
December 8, 2011 at 11:42 am #428677Uhm yes. There is something wrong.
After press save. By somehow … it … cleaned value if bistro.ini profile. And that’s why make messup layout.
I have updated description in backend but restore bistro.ini profile via FTP by manually.
Wired.
May i know what did you do w/ your website ?Thank you
harsa Friendharsa
- August 2008
December 8, 2011 at 1:33 pm #428709<em>@jooservices 287894 wrote:</em><blockquote>Uhm yes. There is something wrong.
Wired.
May i know what did you do w/ your website ?Thank you</blockquote>
hmm,… what i did was just customizing the layout.. didn’t change anything extraordinary.. and i was just started to do changes on the slideshow when this thing started to happen.. for info, i just install 2 external components that are phocagallery and fabrik(for forms).. thats all..
- October 2014
December 9, 2011 at 1:14 am #428834For Joomla! Form i think you can go with rsForm 🙂
It’s perfect solution.Thank you
harsa Friendharsa
- August 2008
December 9, 2011 at 2:07 am #428850thank you jooservices for your help.. really appreciated it..
will look into rsForm..
- October 2014
January 8, 2012 at 6:46 am #432955Hello … I also have run into this problem. I made changes to the description, and they stopped showing up.
Could you clarify what you did to resolve this problem?
Thankyou…
harsa Friendharsa
- August 2008
January 10, 2012 at 8:06 am #433248<em>@co6866 293488 wrote:</em><blockquote>Hello … I also have run into this problem. I made changes to the description, and they stopped showing up.
Thankyou…</blockquote>
Hi, my problem was, it conflicted with other external component because i have installed a form component. Once i removed the form component, the problem was solved. May be you can check what you have installed..
hope this help..
This topic contains 30 replies, has 3 voices, and was last updated by co6866 12 years, 9 months ago.
