  • easykey Friend
    #152726
    Very strange problem, I have an article that has a few named A tags (a name=”title”) with some links at the top of the page to scroll down to the content (a href=”#title”).
    When you click on the links at the top of the page, all the content shifts up a few pixels. It is not really visible till you scroll to the top of the page and notice that the heading has moved up / is being obstructed by the top of the page.
    I have installed a fresh copy of Joomla with the template and it seams to still have the same issue.
    Any help would be appreciated.
    Can you pls give me a link having this problem, i would like to check this.
    easykey Friend
    #351063
    you can see it on:
    http://joomlart.easykey.net/concept/index.php?option=com_content&view=article&id=56&Itemid=53
    this is a fresh quickstart install
    all looks fine but when you click on a link to take you down the page, e.g. “lists” you can see that the heading moves up like the top padding is missing
    Hello
    I think that you using wrong inner links , example: (a href=”#title”) this one is maped with element having id= “title”, not name=
    easykey Friend
    #351240
    That only makes the page smooth scroll, the issue is that the page content seams to move up,
    goto http://joomlart.easykey.net/concept/index.php?option=com_content&view=article&id=56&Itemid=53
    and look where the heading is compared to the top border BEFORE clicking a bookmark link:
    after you click one of the on page bookmark links it moves the heading / content up and the border disappears:
    Hello
    i found this, pls open the template.css file: and find the following code:
    #ja-main .inner { padding: 21px 0 0; }
    replace:
    #ja-main .inner { padding: 0; }
    GOodluck
    easykey Friend
    #351704
    Hello tienhc, thanks for the reply but this has not solved the issue.
    <em>@easykey 188847 wrote:</em><blockquote>Hello tienhc, thanks for the reply but this has not solved the issue.</blockquote>
    Please ctr + f5 and test again, if possbile give the link to your site
    Thanks a lot
    easykey Friend
    #352146
    You can see the quick install with your suggested fix applied by going to:
    http://joomlart.easykey.net/concept/index.php?option=com_content&view=article&id=56&Itemid=53#heading2
    It still has the same issue.
    HEllo
    i fixed this issue :D, please add the following code into the template.css file:
    #ja-contentwrap .column {
    overflow:visible !important;
    GOodluck
    easykey Friend
    #352604
    Thanks Tienhc!
This topic contains 11 replies, has 2 voices, and was last updated by  easykey 14 years, 4 months ago.
