  • zafererel Friend
    #125829
    why this is looking like that:
    http://img509.imageshack.us/img509/9568/rochea1md4.jpg
    how can i fix? i didnt do anything? only installed template? used 1.0.14 joomla
    csaling Friend
    #239785
    I think it is because you have to many menu items in the main menu.
    I can only use six. So I made other a sub-menu on the main menu.
    Try it and see if it works.
    Carl
    mfcphil Friend
    #239839
    Have you tried the suckerfish menu instead of the slit menu?
    To choose your menu type, go to the 36th line in the “ja_Rochea/ index.php” and change
    $ja_menutype to what you need.
    1 is Split Menu, 2 is Suckerfish Menu, 3 is Transmenu
    It will probably be already on Split
This topic contains 3 replies, has 3 voices, and was last updated by  mfcphil 16 years, 9 months ago.
