  • doorknob Friend
    #193373
    Whilst investigating a problem with the layout file I inspected the php error log and found it full of ob_clean() errors. On further investigation, I found that the output buffer is cleared whether it exists or not. I fixed it for me by changing t3/includes/admin/layout.php line 109 from:
    ob_clean();
    to
    $ob_status = ob_get_status();
    if (isset($ob_status['status']) && $ob_status['status'] != PHP_OUTPUT_HANDLER_START) {
    ob_clean();
    Now my php errors file doesn’t fill up so fast.
    Phil
    Wall Crasher Developer
    #517106
    Thank for your report on the output buffering issue, we will apply the fix you suggest.
This topic contains 2 replies, has 2 voices, and was last updated by  Wall Crasher 10 years, 11 months ago.
