  • mgruber Friend
    #151964
    Dear guys,
    i’am already working on a JA QUARTZ Template in combination with some JA Extensions.
    Now i have the problem, that images i add in an article with TinyMCE (embedded in the text on the upper right side with text floating), the image is positioned in the upper left edge of the browser window.
    I cannot upload any extension this time, but i positioned a screenshot on the server. you can have a look here: http://www.lizardclimbing.com/_work/bild_seite.JPG
    Has anybody an idea what i have to do that the image (the portrait) has the correct position?
    Thanks and Greetings,
    Martin
    Dear mgruber!
    Those texts are using for display Tabs. did you enable the ja tabs plugin?
    pls try to check again
    thanks
    mgruber Friend
    #348901
    Dear tienhc,
    thanks for that information. It looks like it would work now. I did only activate the ja tabs module, but not the plugin.
    Martin
    mgruber Friend
    #349016
    Thanks for your tip with the tabs plugin. Now its working on all sites very fine, but only the startpage does not work correctly.
    Here you can see the effect: http://www.lizardclimbing.com/site
    Thanks,
    Martin
    pls open the file template.css and find the following code:
    div.img-desc {
    position: absolute;
    top: 0;
    left: 0;
    replace:
    div.img-desc {
    Good luck
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 14 years, 4 months ago.
