  • soil Friend
    #186364
    Hi there!
    It´s always the same. I had the same problem with JA ZITE. If you place an image in slider…it does not look always the same in different browsers or screen resolutions. Soemtimes it is shrinked, sometimes it is not in the middle or it is bloated. What is the problem? Whre can this be fixed?
    Best,
    Soil
    TomC Moderator
    #488495
    Can you, perhaps, provide the url of your site – so we can take a look in different browsers to see if we can duplicate the issue?
    OR, you can perhaps utilize something like BROWSERSHOTS and provide the link to the [Browsershots] page for your site and we can take a look that way too.
    Ninja Lead Moderator
    #488552
    You can browse to userguide section of JA templates here and find JA Puresite and JA Zite template configure them as per the userguide. If you still face the same problem, you can give me the screenshot and url of your site. I might be able to help you out. Right now its difficult to guess the issue and solution without actually being able to see it.
This topic contains 3 replies, has 3 voices, and was last updated by  Ninja Lead 11 years, 9 months ago.
