  • puntje Friend
    #907482
    I have a plugin form maker for contact forms that does not work with this template. The developers op this plugin checked it on my website and it turns out that any plugin shortcakes generally don’t work with the template moviemax. The switched to another template, to see it will load and it did.
    So they asked me to contact the team developers of Moviemax template to look at this problem
    Hope you can help me soon it is a bug
    Could you send me URL of page where this plugin is being used? and sample of how it should be?
    puntje Friend
    #907987
    I just updated this file on your site a bit: /html/com_content/article/default.php
    By replacing the line of code (at approx line 86): <?php echo $this->item->introtext; ?>
    with: <?php echo $this->item->text; ?>
    and the form is showing now, you can take a look.
    puntje Friend
    #908830
    Yes i see. thanks
    You’re welcome!!!
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 8 years, 7 months ago.
