  • labbyjoel Friend
    #196576
    I’m curently developping a website with k2 item geolocalisation. I’m using sw k2 maps as plugin.
    This plugin works well with category and tags views but is not present on search made with JA K2 SEARCH
    I’ve activated the k2 plugins into the JA K2 Search options; but without any result.
    Does anybody have an idea ??
    Thanks a lot !
    joe
    Thanh Nguyen Viet Friend
    #530230
    Hi Joe,
    This issue occured because K2 does not check the setting when turning on/off K2 plugins on search view. To fix this, please open the /components/com_k2/models/item.php file:
    Replace this code snippet:
    [PHP]if (($view == ‘item’ && $item->params->get(‘itemK2Plugins’)) || ($view == ‘itemlist’ && ($task == ” || $task == ‘category’) && $item->params->get(‘catItemK2Plugins’)) || ($view == ‘itemlist’ && $task == ‘user’ && $item->params->get(‘userItemK2Plugins’)) || ($view == ‘itemlist’ && ($task == ‘search’ || $task == ‘tag’ || $task == ‘date’)))[/PHP]
    With:
    [PHP]if (($view == ‘item’ && $item->params->get(‘itemK2Plugins’)) || ($view == ‘itemlist’ && ($task == ” || $task == ‘category’) && $item->params->get(‘catItemK2Plugins’)) || ($view == ‘itemlist’ && $task == ‘user’ && $item->params->get(‘userItemK2Plugins’)) || ($view == ‘itemlist’ && $item->params->get(‘catItemK2Plugins’) && ($task == ‘search’ || $task == ‘tag’ || $task == ‘date’)))[/PHP]
    labbyjoel Friend
    #530726
    thanks for your reply, but this trick does not seems to resolve the issue.
    I’ve set a “print” into the “/components/com_k2/models/item.php” file to check if the process enter in the “if” and It enters well now with the code modification you give, but the map is not displayed as attended.
    I works well with category view and tag view. but not in search view.
    after some other research I get this post : http://styleware.eu/forum/Google-maps-Extensions/5513-Plugin-not-loading-on-category-view
    I seems that the sw k2 maps is not compatible with ja filter..
    It seems you don’t use the k2 itemlist model but another one.
    in fact in they code, they use this :
    [PHP] $model = new K2ModelItemList();
    $count = $model->getTotal();
    [/PHP]
    The result when using a search with ja filter is always 0 !
    may be do you have a trick to make your plugin compatible ?
    thanks
    #530740
    Please PM me your Administrator and FTP credentials, I will help to debug and give you suggestion then.
    labbyjoel Friend
    #531022
    thank you !
    I’ve contacted the developpers of sw k2 maps and they modify their plugin to be compatible with yours ! So all is fine for me !
    if anybody encount the same problem, try to change this line in the swmap.php file
    [PHP]$model = new K2ModelItemList();[/PHP]
    with
    [PHP]if(class_exists(“JAK2FilterModelItemlist”)){
    $model = new JAK2FilterModelItemlist();
    }else{
    }[/PHP]
    joe
This topic contains 5 replies, has 2 voices, and was last updated by  labbyjoel 10 years, 7 months ago.
