  • piri314 Friend
    #172025
    I downloaded the quiqstart of Ja Enrio and the latest version of K2.
    I just find that
    – If the plugin System – K2 is activated: the modules based on slides (images show, content slider) do not work.
    – If the plugin System – K2 is disabled: the modules slides K2 works but K2 displays errors…
    Can you help please ?
    PIRINA
    khoand Friend
    #430724
    Go to the k2 component setting, click on the Parameters setting at the top right, there select the jQuery library handling field to Load v1.6.3( local copy ) and it helped
This topic contains 2 replies, has 2 voices, and was last updated by  khoand 13 years ago.
