August 30, 2011 at 10:17 pm #168006
I have problem on my test site with words with letters typical for Polish language. All modules (titles) are bold but without “polish” letters. In main menu (magazine) words with Polish letters are lower (Firefox) or without bold (IE9 comp. mode only). Take look at attached pictures, please.
- jooservices Friend
jooservices
- October 2014
- 1245 times in 1121 posts
September 6, 2011 at 8:35 am #410911<em>@piotras100 264065 wrote:</em><blockquote>I have problem on my test site with words with letters typical for Polish language. All modules (titles) are bold but without “polish” letters. In main menu (magazine) words with Polish letters are lower (Firefox) or without bold (IE9 comp. mode only). Take look at attached pictures, please.</blockquote>
Would you mind PM with your site URL for checking ?
Thank you
Viet VuSeptember 6, 2011 at 4:52 pm #411028I have send PM to You…
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
September 6, 2011 at 5:13 pm #411037I think that is a problem with the fount being used here. As a test can you go into the templaye manager and in the profiles section select one of the default fonts such as Aerial just for the menu and lets see if it makes a difference.
September 6, 2011 at 6:52 pm #411049I have no such font in Latin and Latin Extended 🙁
But I will try wit another – hope that I will find similar with “polish” chars 🙂
September 6, 2011 at 7:48 pm #411057No way…
I have tryed 6-8 fonts and “Polish” chars are not in bold (even they are correct on Google Web Fonts page). Sometimes after changing the font, Polish chars in modules names were also in a different font then other (non Polish) chars.
Another thing, when I have changed fonts for modules, font in modules with Tabs was unchanged.
I was also trying to change font for Main Menu – the same problems with Polish “chars” as earlier.
I have also changed names of modules to see if there is difference on page between NAJCZĘŚĆIEJ or najczęściej. (second screen)
- September 6, 2011 at 8:17 pm #411061
Phill, is it possible to “turn off” Google web-fonts? I have never any problems with standard family fonts as Arial, Helvetica etc. on my other pages (also based on Joomla nad JA template or another). For example take look at http://www.markiewicz.info or http://www.springsteen.pl
jooservices Friendjooservices
- October 2014
September 7, 2011 at 12:56 am #411081Hi
Yup this’s issue with font. Btw i don’t have your back-end access , so i’ve tried to do in css#1 Module right:
NAJCZĘŚCIEJ CZYTANE
Najnowsze
File:
plugins/system/jatabs/jatabs/themes/teline_iv/style.css
Line 76: Remove
font-family: ArialNarrowBold,"Arial Narrow",Arial,sans-serif;
Line 50: Remove
So you’ll have like this ( my attachment screenshot )
I’ll try to keep find w/ another place in few min.
ps:// actually you can PM with your back-end access than i can help you for checking remove use Google font.
or you can do like this
.contentheading, .componentheading, h1, h2, h3, h4, h5 {
font-family: Georgia,Cambria,"Times New Roman",Times,serif !important;
Because you are using compressing mode so i can say exactly where is it. But i guess it’s template.css
You can patch this and it should be fine.
Thank you
Viet Vu
September 7, 2011 at 1:52 am #411085I have sent a PM
AuthorPostsViewing 9 posts - 1 through 9 (of 9 total)This topic contains 9 replies, has 3 voices, and was last updated by piotras100 13 years, 1 month ago.
Problem with Polsh letters in magazine menu and module titles
