  • art3 Friend
    #196650
    Good afternoon, I have a problem with Popup Content (attached image).
    I want background display.
    Can I use a direct link? No popup,
    Thanks.
    1. error-background
    goodpixel Friend
    #530464
    Hello, can’t login with credentials provided, can you verify access please?
    art3 Friend
    #531154
    Hi, Goodpixel, send private access Thanks
    goodpixel Friend
    #531191
    Hi Art, problem solved!
    In your JA Content Popup module, we have in basic option configuration (right side of module), a option called ‘Show Pop-up’, indicate ‘NO’ and your links open in normal window, like our demo. If you set to YES can adjust sizes and the content opens in a modal pop-up window.
    Thanks!
    art3 Friend
    #531271
    Perfect, thank you very much!
    Problem solved. :laugh:
This topic contains 5 replies, has 2 voices, and was last updated by  art3 10 years, 8 months ago.
