  • folamour Friend
    #166604
    its still the same issue in fact i’ve the modified template.css, and i’ve the layout at
    /* MAIN LAYOUT DIVS
    .wrap { width: 100%; clear: both; }
    .main { width: 1170px; max-width: 1170px; margin: 0 auto; position: relative;}
    that’s make :
    [/URL]
    the image is not donwloaded that normal, but the text is on the rigth NOT on the bottom,
    normally she look like,
    [/URL]
    i’ve tryed the same parameter as joomla 1.5 in layout.css
    /* MAIN LAYOUT DIVS
    .main { width: 980px; max-width: 1200px; margin: 0 auto; position: relative;}
    that work but the global width is smaller
    [/URL]
    hope you can help
    folamour Friend
    #402617
    that’s ok there is another file in C:xampphtdocstemplatesja_purity_iilocaletcprofiles called default.ini
    change the screen_fixed_width=”1200″
    here i’ve set it to 1200 and according to template.css
    /* MAIN LAYOUT DIVS
    .main { width: 1200px; max-width: 1200px; margin: 0 auto; position: relative;}
    that’s make :
    [/URL]
    i’ll think a certain site will goes up in 1.7 ; )))
    hope the logo and template will look in real like in lab, not like in http://www.crashdebuglab.fr
    have a nice days,
    himangi Friend
    #402847
    Hi folamour,
    Can you please tell me if your problem is solved or not? If not, kindly explain it again and please provide your site admin details at http://support.joomlart.com/index.php?/Tickets/Ticket/View/77230 so that I can take a look at your site and try to give you a solution..
    folamour Friend
    #402851
    yes it ok himangi ! don’t worry all work fine ; ))))) you can close the thread, and the case, many thanks
This topic contains 4 replies, has 2 voices, and was last updated by  folamour 13 years, 5 months ago.
