  • rimas Friend
    #129612
    I’m install “ja_avian_ii_quickstart_v1.2_1.5.3” . No other changes. When press pdf button in article have such problem:
    Warning: TCPDF::require_once(/home/domain/domains/domain.com/public_html/avian2/libraries/tcpdf/unicode_data.php) : failed to open stream: No such file or directory in /home/domain/domains/domain.com/public_html/avian2/libraries/tcpdf/tcpdf.php on line 6254
    Fatal error: TCPDF::require_once() [function.require]: Failed opening required ‘/home/domain/domains/domain.com/public_html/avian2/libraries/tcpdf/unicode_data.php’ (include_path=’.:/usr/share/pear’) in /home/domain/domains/domain.com/public_html/avian2/libraries/tcpdf/tcpdf.php on line 6254
    Please help. Thank you
    #253366
    Hi.
    I will update it in latest version, plz wait
    rimas Friend
    #253375
    When will it happen ?
    Could you suggest some workround ?
    #253377
    You can download this package 1772, unzip then copy overwrite to your site folder. This is default patch from joomla 1.5.2 to joomla 1.5.3,your site have that error because quickstart miss some files.
    We wil update it early. Regards
    rimas Friend
    #253418
    Nice try, but this doesn’t work. 🙁
    #254093
    Hi.
    Download this file 1807, unzip end copy to librariestcpdf folder
    Good luck
This topic contains 6 replies, has 2 voices, and was last updated by  Sherlock 16 years, 6 months ago.
