  • roberttoma Developer
    #197029
    I tried to install the package (both 3.2 and 2.5) quickinstall of this template, but It appear incomplete in both versions. You can see this in the link attached. Thanks
    TomC Moderator
    #532160
    It does not appear that you installed the sample data as part of the quickstart installation process.
    SEE THIS REFERENCE —> QUICKSTART INSTALLATION
This topic contains 2 replies, has 2 voices, and was last updated by  TomC 10 years, 8 months ago.
