Pankaj Sharma Moderator
October 4, 2016 at 1:08 am #973188Hi
Kindly increase the PHP values on your server , increase below values :
max execution time (300)
memory limits : 256M or 512M
After changes , download the fresh package and install it on fresh Directory and Database with help of documentation .
Hope it helps .vivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 4, 2016 at 8:54 am #973322Hi Pakaj
I have 300 (time) and 256 (memory) but It doesn’t work… (I can’t change server to bring it to 512).
Is there something else to try?
Thanks in advance…
VivaldoPankaj Sharma ModeratorPankaj Sharma
October 4, 2016 at 8:59 am #973329This reply has been marked as private.vivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 4, 2016 at 10:31 am #973367Thanks Pankaj
I will send you privately the credentials.
The values I indicated were already in use…
Vivaldovivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 4, 2016 at 12:26 pm #973392Pankaj I did it but I can’t have the demo site installed: I chose installa sample data.. it was an error? Thanks
You can find it here:
http://www.castelgandolfobedbreakfast.it/site/index.phpvivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 4, 2016 at 2:58 pm #973451Hi Pankaj
I did a new installation and had the error: 500 Unable to load renderer class
you can find it here:
http://www.castelgandolfobedbreakfast.it/wet/index.phpPankaj Sharma ModeratorPankaj Sharma
October 4, 2016 at 3:16 pm #973461Hi
when I checked your site last time it was working while the only issue was you haven’t installed the simple data on your site this was the reason why was not like the demo that resulting the 404 .
Can you provide me the temporary super user details of the sites so I can take a look and let you know about the cause of issuevivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 4, 2016 at 6:45 pm #973553This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
October 5, 2016 at 1:27 am #973598Hi
This is working fine : http://www.castelgandolfobedbreakfast.it/site/index.php
But you forget to install sample data in the 3rd step of installation . You have to install sample data to get the site like in the demo .
Both the site does not have all the sample date .
Kindly provide me with the asked details above , so I can help u to install the package .vivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 5, 2016 at 6:51 am #973668This reply has been marked as private.Pankaj Sharma ModeratorPankaj Sharma
October 5, 2016 at 7:29 am #973683This reply has been marked as private.vivaldo moscatelli Friendvivaldo moscatelli
- March 2015
October 5, 2016 at 2:49 pm #973777Hi Pankaj
I uploaded the fresh quick start package in the /cem directory.
I used utf8_general_ci database collation for the db tables
I’ll be waiting for you.
VivaldoNinja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
October 6, 2016 at 1:48 am #973937Hi Vivaldo,
I need to check the problem directly on your hosting, please give me the Cpanel of your hosting via private reply. I will help you out.
- March 2015
October 6, 2016 at 12:56 pm #974148This reply has been marked as private.Ninja Lead ModeratorNinja Lead
- November 2014
October 7, 2016 at 2:26 am #974262This reply has been marked as private.1 user says Thank You to Ninja Lead for this useful post
This topic contains 16 replies, has 3 voices, and was last updated by vivaldo moscatelli 8 years, 1 month ago.
The topic ‘Problem with quickstart’ is closed to new replies.
