September 27, 2011 at 5:17 pm #169025
I put the ziped quickstart file in my FTP and I unziped it.
I began the installation, I put the correct Mysql informations, but when I go to next step this mensage appeared:
Você tem um erro de sintaxe no seu SQL próximo a ‘TYPE=MyISAM AUTO_INCREMENT=9’ na linha 29 SQL=CREATE TABLE `jos_banner` ( `bid` int(11) NOT NULL AUTO_INCREMENT, `cid` int(11) NOT NULL DEFAULT ‘0’, `type` varchar(30) NOT NULL DEFAULT ‘banner’, `name` varchar(255) NOT NULL DEFAULT ”, `alias` varchar(255) NOT NULL DEFAULT ”, `imptotal` int(11) NOT NULL DEFAULT ‘0’, `impmade` int(11) NOT NULL DEFAULT ‘0’, `clicks` int(11) NOT NULL DEFAULT ‘0’, `imageurl` varchar(100) NOT NULL DEFAULT ”, `clickurl` varchar(200) NOT NULL DEFAULT ”, `date` datetime DEFAULT NULL, `showBanner` tinyint(1) NOT NULL DEFAULT ‘0’, `checked_out` tinyint(1) NOT NULL DEFAULT ‘0’, `checked_out_time` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `editor` varchar(50) DEFAULT NULL, `custombannercode` text, `catid` int(10) unsigned NOT NULL DEFAULT ‘0’, `description` text NOT NULL, `sticky` tinyint(1) unsigned NOT NULL DEFAULT ‘0’, `ordering` int(11) NOT NULL DEFAULT ‘0’, `publish_up` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `publish_down` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `tags` text NOT NULL, `params` text NOT NULL, PRIMARY KEY (`bid`), KEY `viewbanner` (`showBanner`), KEY `idx_banner_catid` (`catid`) ) TYPE=MyISAM AUTO_INCREMENT=9
My site is: http://www.sintespo.com.br
pavit Moderatorpavit
September 27, 2011 at 5:32 pm #415331Hi wesleydalcolleite
Which type of mysql information have you inserted ? the details of your new DB ? or the old details ?
October 3, 2011 at 5:01 pm #416521I created one DB to install the quickstart, How can I fix that?
October 3, 2011 at 5:26 pm #416530Hi
Could you provide via Private message your db details i’m on your installation page i will try to continue and see the problem
October 4, 2011 at 3:21 pm #416779I sent to you
October 4, 2011 at 3:22 pm #416780Ok thanks
I will try now
October 4, 2011 at 3:33 pm #416784Hi wesleydalcolleite
Can i have your ftp account via Private Message ? I put again the quickstart package in your folder and i’ll try to make the installation for you
i already have your DB account
October 5, 2011 at 4:33 pm #417064I sent to you
October 5, 2011 at 5:45 pm #417083Ok thanks i’ve received your Pm let me some time
October 5, 2011 at 7:23 pm #417108Hi wesleydalcolleite
Sorry only now i figured that you have some errors that can be managed from your hasting provider see pic Ask them to put your Register Globals directive to OFF
October 7, 2011 at 1:49 pm #417524Done, the Register Globals directive is OFF
October 7, 2011 at 2:55 pm #417535Hi
I’m trying to make a fresh quickstart installation on your site
October 7, 2011 at 6:59 pm #417607Hi
Please could you manually delete through your cpanel all the joomla files in your folder ?
I’m having problem to delete some files on your server
When you have deleted all files i’ll upload my quickstart files with filezilla
October 11, 2011 at 3:39 pm #418492I sent a private message to you
October 11, 2011 at 3:43 pm #418493Thanks for the PM
I try again to upload all the quickstart package
AuthorPostsThis topic contains 18 replies, has 2 voices, and was last updated by pavit 13 years, 1 month ago.
