January 6, 2013 at 3:05 pm #183698
I have followed the instructions according on how to clone the demo as per below link. http://www.joomlart.com/blog/tutorials/how-to-clone-the-demo-using-quickstart-installation-a-step-by-step-guide
but It still reflect internal server error on my frontend whereas my backend is working perfectly fine. http://www.pokersg.org/officialyoyopoker2/
Please help to solve this problem?
pavit Moderatorpavit
January 6, 2013 at 5:11 pm #478595Hi
Could you specify which errors are you watching ?
because by my side your front end is showing correctly i cannot see any error
January 7, 2013 at 6:33 am #478658The front end has been solved, it is due to the php. Now I have another problem.
All my backend articles shown internal server errors. Please give me the solution.
January 7, 2013 at 8:57 am #478682Hi
Please send me a PM with your accounts details for login i will try to check your configuration
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by pavit 11 years, 11 months ago.
Problem with quickstart installation
