  • anoopxyz Friend
    #133626
    I have deleted my old joomla installation and installed Ja Rutile quickstart pack.
    Now the problem is, I can see the home page properly.. no any other pages are working well.
    Some show 404 error some pages open just white page with blue text.
    What could be the problem… please check my site http://www.qualishopper.com
    Thanks.
    #271995
    please turn on mod_rewrite
    and change htaccess.txt to .htaccess
    anoopxyz Friend
    #272048
    Thanks for your reply… I changed htaccess.txt to .htaccess
    But couldn’t find mod_rewrite
    And the problem still persists.
    Plz tell me where I can find mod_rewrite
    Regards,
    Menalto Friend
    #272052
    Go to admin panel and Site>Global configuration,, on right side there you have SEO Settings
    and set Search Engine Friendly URLs to yes and Use Apache mod_rewrite to yes.
    But in another hand, this should not be needed to do on the quickstart package??
    #272054
    you will see like image when go to admin, Site-> Global Configuration
    2917
    Config as image
    anoopxyz Friend
    #272063
    It worked… The problem was in that place….
    I gave no to all those threee fields…
    Thanks a lot
    Cheers.
This topic contains 6 replies, has 3 voices, and was last updated by  anoopxyz 16 years, 2 months ago.
