  • dion77 Friend
    #167349
    Dear all,
    In the installation of quickstart package and after the Database Configuration i get the following message :
    Some errors occurred while populating the database: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘TYPE=MyISAM’ at line 41 SQL=CREATE TABLE `jos_weblinks` ( `id` int(10) unsigned NOT NULL AUTO_INCREMENT, `catid` int(11) NOT NULL DEFAULT ‘0’, `sid` int(11) NOT NULL DEFAULT ‘0’, `title` varchar(250) NOT NULL DEFAULT ”, `alias` varchar(255) NOT NULL DEFAULT ”, `url` varchar(250) NOT NULL DEFAULT ”, `description` text NOT NULL, `date` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `hits` int(11) NOT NULL DEFAULT ‘0’, `state` tinyint(1) NOT NULL DEFAULT ‘0’, `checked_out` int(11) NOT NULL DEFAULT ‘0’, `checked_out_time` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `ordering` int(11) NOT NULL DEFAULT ‘0’, `archived` tinyint(1) NOT NULL DEFAULT ‘0’, `approved` tinyint(1) NOT NULL DEFAULT ‘1’, `access` int(11) NOT NULL DEFAULT ‘1’, `params` text NOT NULL, `language` char(7) NOT NULL DEFAULT ”, `created` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `created_by` int(10) unsigned NOT NULL DEFAULT ‘0’, `created_by_alias` varchar(255) NOT NULL DEFAULT ”, `modified` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `modified_by` int(10) unsigned NOT NULL DEFAULT ‘0’, `metakey` text NOT NULL, `metadesc` text NOT NULL, `metadata` text NOT NULL, `featured` tinyint(3) unsigned NOT NULL DEFAULT ‘0’ COMMENT ‘Set if link is featured.’, `xreference` varchar(50) NOT NULL COMMENT ‘A reference to enable linkages to external data sets.’, `publish_up` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, `publish_down` datetime NOT NULL DEFAULT ‘0000-00-00 00:00:00’, PRIMARY KEY (`id`), KEY `idx_access` (`access`), KEY `idx_checkout` (`checked_out`), KEY `idx_state` (`state`), KEY `idx_catid` (`catid`), KEY `idx_createdby` (`created_by`), KEY `idx_featured_catid` (`featured`,`catid`), KEY `idx_language` (`language`), KEY `idx_xreference` (`xreference`) ) TYPE=MyISAM ;
    What’s wrong ?
    Val Kupstas Friend
    #406032
    Take a look at this link here if it will help you:
    http://www.joomlart.com/forums/topic/some-errors-occurred-while-populating-the-database-when-installing-sample-data/
    <em>@dion77 259458 wrote:</em><blockquote>Dear all,
    What’s wrong ?</blockquote>
This topic contains 2 replies, has 2 voices, and was last updated by  Val Kupstas 13 years, 3 months ago.
