  • f06d2 Friend
    #140820
    I would like to change it or revert to the standard configuration of joomla never have: more info +
    to have the text translated into french ..
    I delete the file-GB.tlp_jaruby.ini in the language but nothing changes …
    I repeat an installation with only the template, but it still appears.
    how to stop it ? thank you
    Arvind Chauhan Moderator
    #303274
    Take backup and open
    /templates/ja_ruby/html/com_content/frontpage/default_item.php
    Line 161 change More info + to your preference.
    [PHP] <?php echo JText::_(‘More info +’); ?>[/PHP]
    Also change
    /templates/ja_ruby/html/com_content/category/blog_item.php
    line 158 change More info + to your preference
    [PHP] echo JText::_(‘More info +’);[/PHP]
    Hope this helps.
    regards
    arvind
    f06d2 Friend
    #303286
    thank you it’s all right,
    but i have delete the file-GB.tlp_jaruby.ini in the language it’s a important file for the operation of the site…
    #303289
    You can replace the same file from the Ja Ruby Download file. I am attaching the default file for you. You can replace the file. Next time instead of deleting, rename the files, so that you can always undo your changes. Taking backup before touching files is always a wise idea.
    en-GB.tpl_ja_ruby.ini
    regards
    arvind
    f06d2 Friend
    #303436
    yes but it is important that the template works
This topic contains 5 replies, has 2 voices, and was last updated by  f06d2 15 years, 8 months ago.
