October 20, 2011 at 4:52 pm #169871
my Slideshow2 Module loads the images from the folder “events”.
In the folder I have just 4 items, but in the module I see 6 items, with 2 items repeated on the left side and on the right side.
How can I avoid this?Thank you,
Armandokhoand Friendkhoand
- February 2011
- 1166 times in 1060 posts
October 20, 2011 at 5:10 pm #420540Hi,
Could you give me a link to your website?October 20, 2011 at 6:21 pm #420561sure
http://www.vicstreet.it/temp
thank you
- February 2011
October 21, 2011 at 3:54 am #420621I see 3 picture on event slideshow. You try delete all of files of http://www.vicstreet.it/temp/images/resized/images/stories/jaslideshow/ folder
October 25, 2011 at 8:19 am #421421I haven’t solved my problem.
The link to my site is the same.
For example, in the folder (eventi) I have just 9 items but in the module I see 11 items, with the first one and the last that repeat themselves.
I don’t know how to avoid this. Can someone help me?
thank you,
- February 2011
October 25, 2011 at 6:42 pm #421539You give me username+password of your backend and ftp to check.
khoand Friendkhoand
- February 2011
October 26, 2011 at 4:21 pm #421703I get a error: 530 Login authentication failed
Could you check your ftp information, please?khoand Friendkhoand
- February 2011
October 27, 2011 at 3:03 am #421791Ok. I can access your ftp. I am checking it. I removed your post because of security
khoand Friendkhoand
- February 2011
October 28, 2011 at 10:16 am #422147Actually that is not a problem , if the “Mark Style” field is set to Full size the module will auto clone the first and the last item into the item list, if it does not insert two more those items then the slide will look bad with spaces at it’s end .
I hope you understand what i meant !
This topic contains 9 replies, has 2 voices, and was last updated by khoand 13 years, 2 months ago.
