  • Xinxeta Multimedia Friend
    #167240
    I’ve set to hide the main index frontpage content, however this seems to cause a problem with resetting password and remind username page as it seems to be using the main index to output the page.. (which is hidden).
    Is there a way to make the reset password / remind user name page to appear in another itemid?
    http://nuestrasbandasdemusica16.com
    himangi Friend
    #405383
    You can create a new menu item for login type of menu, that should solve the problem.
    #405386
    I create a new menu item for login, but reset pasword and user only works in the login page, not in others
    himangi Friend
    #405581
    I checked and tried again to se if the different type of menu works but the urls in the Login modules are taking Itemid of the page currently being viewed and doesnt work as you want, so it seems you will need to show the main content block on all pages..
This topic contains 4 replies, has 2 voices, and was last updated by  himangi 13 years, 3 months ago.
