  • maxilgatto Friend
    #186262
    Hi, I have a problem with mobile parameter in my site (Joomla 2.5.9, ja_purity_ii 2.5.2, JA T3 2.5.6). Normally all works fine but if I
    change iphone_layout (in template_manager/modify/profiles/layout settings) from “default” to “iphone”, (without any other change) the desktop home page doesn’t more work correctly and its aspect assume something like the mobile layout. Some suggestion? Thanks
    Manos Moderator
    #488056
    I am not sure i get your question, it’s obvious that since you change from default to iphone is like forcing the layout to render for iphone.
    Am i missing something here?
    Manos
    maxilgatto Friend
    #488133
    Thanks for reply. The problem is that, after changing from “default” to “iphone” in the iphone layout and saving configuration, the server seems to force the iphone layout to the desktop browser too. Here you see the desktop image before change and here after . You can see the icon for changing display from mobile to desktop. Is it normal? Thanks
    1. 2013-03-28_100959
    2. 2013-03-28_100845
    3. 2013-03-28_101538
    Manos Moderator
    #488163
    Switch to normal since the version you use has JS code to determine the device that the site is accessed and this is why you get the forced iphone layout when you make that change.
    Manos
    maxilgatto Friend
    #488203
    Thanks for response, but I don’t understand what do you exactly mean for “normal”: where have I to switch?
    Thanks and excuse for my not understanding…
    Manos Moderator
    #488209
    Please switch to default and let’s see how it goes! Do you have any JS conflicts or something ?
    Manos
    maxilgatto Friend
    #488265
    Hi Manos, after setting all profile to “default” , when I link to my home page (HP) I continue to see the mobile layout and only after forcing the desktop layout to desktop (button on the lower part of HP) i begin to see the correct layout on the computer screen : of course, before traying, I cleaned the browser cache. The same happens if I link to my HP from a different browser from my computer or from a second computer. It seems to me that there is something incorrect on the JS but i dont know what….
    Thanks for attention
    Manos Moderator
    #488288
    This is why i asked you if you noticed any JS conflicts, also clear cache is not the only thing you need to do, you also have to clear cookies .
    A link to your installation might help.
    Manos
    maxilgatto Friend
    #488312
    Hi, I didn’t notice any kind of conflict in JS (no messages). The front end site is montessorinet.it.
    Manos Moderator
    #488314
    Check the JAT3 plugin version etc you have installed, unfortunately i have no iPhone and on my Android your site looks like the desktop version ( i guess you haven’t configured that )
    Manos
    maxilgatto Friend
    #488319
    Yes, I’do and I will let you know the result: now effectively I have all profiles configured as “default”
    thanks
    maxilgatto Friend
    #488358
    Hi, i guess you’re right ’cause I have older versions of ja_purity_ii (2.5.2 instead of 2.5.3) and of Ja T3 Framework plugin (2.5.6 instead of 2.6.1) but, trying to update ja_purity_ii I receive an error message (copy failed). What does it mean? Perhaps have I to update T3 Plugin before? Another site of mine (working with up to date template and plugin works fine) but how could I solve the update problem? Thanks again
    Manos Moderator
    #488362
    You need to check the write settings under the folder that Joomla needs to write in order to update your files.
    Manos
This topic contains 13 replies, has 2 voices, and was last updated by  Manos 11 years, 8 months ago.
