  • rabbito Friend
    #206030
    I have some issues regarding the site I am building. The URL is http://www.test.etmagazine.eu
    The desktop layout works fine, but when loading on tablets or mobiles a lot of issues occur, especially on 4-5? display smartphones.
    1. Logo’s right side is cropped.
    2. The menu that is on the left is unreachable.
    3. On the front page I use module Slideshow Lite 4×2, which on small displays is invisible.
    4. All text items 1×1 on tablets/phones have their text cropped.
    5. In grid empty blocks appear.
    Please help
    Ninja Lead Moderator
    #569326
    You can find my answer for your questions as below
    1) Within T3 framework, you can set logo for normal / desktop layout and mobile layout separately:
    2) What did you change on off-canvas menu on mobile device? I see structure html and css are different from the original of JA Fixel template
    3) Because the layout in mobile device is very small and the slideshow lite module was hidden from css style and you can enable it but you have to make the style on it. This way will help you to enable it
    Open templates/ja_fixel/css/custom.css file add new rule
    @media (max-width: 767px) {
    .items.slideshow, .t3-module.slideshow {
    display: block;
    4, 5) Can you give me the screenshot and URL of your site to see that issue? I will help you to debug it.
    1. Screen-Shot-2015-05-04-at-16.44.29
    rabbito Friend
    #569411
    Thank you for your answer, Ninja Lead
    These are the results:
    1. As you can see in the screenshots, when activating the small logo overlapping occurs.
    2. I do not remember the files I have changed. Do I have to restore the original files? If so, which ones? If you need ftp access, I will send PM.
    3. The Slideshow Lite module on the front page is fixed!
    4-5. See the screenshots for the empty blocks and the cropped text.
    1. ipad
    2. phone
    rabbito Friend
    #734500
    #569491
    1) I checked directly from backend of your site and saw logo-small on your site with dimension 246×30 but I changed it to 38×30 and it’s working fine on mobile layout
    2) Please backup all files on your site first, I will help you to sync it with original files from download page.
    4-5) I hope after restoring with original files, it will work fine.
    rabbito Friend
    #569559
    I made full file & sql backup. What is the next step?
    rabbito Friend
    #734648
    #569613
    <em>@rabbito 472040 wrote:</em><blockquote>I made full file & sql backup. What is the next step?</blockquote>
    and you can go download page here download and install all extensions and template on your site. It will help you to get back original files
    #734702
This topic contains 9 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 6 months ago.
