swissa Friend
swissa
- November 2011
- 717 times in 572 posts
March 20, 2014 at 11:44 am #527479Josep,
Remove the login details – you’ll get hacked otherwise. Send new ones via a Private Message to Ninja Lead and cancel the old ones.
1 user says Thank You to swissa for this useful post
March 20, 2014 at 12:40 pm #527486Ok. You’re right: I have not thought about it 🙁
I changed the keys. But: how can I send you a private message?Another thing: you can delete my previous comment?
thanks
swissa Friendswissa
- November 2011
March 20, 2014 at 12:51 pm #527487<em>@josep masso 417322 wrote:</em><blockquote>Ok. You’re right: I have not thought about it 🙁
thanks</blockquote>
I can’t delete anything as I don’t work here! 😉
To send a PM click on Ninja Lead’s name and then pick send PM.
March 20, 2014 at 1:28 pm #527492Ok. Thank you.
I have sent a private message to Ninja Lead.
I’m waiting for the answer.
Thank you!
March 20, 2014 at 5:01 pm #527506<em>@josep masso 416365 wrote:</em><blockquote>What I try to explain is this:
The user enters “Monogràfics” for example.
If you try to click on any of the items on the main menu does not work the link. The page can not go to the specified url with anchor.
Only the first menu item (Home), which is the only one who does not have the anchor work 🙁How I can fix this?
Thanks!</blockquote>
Please: you found a solution? I have to finish this web site and I need just the item in the main menu.
Thank you.
March 20, 2014 at 8:10 pm #527524I’m seeing that this template is difficult to integrate, the part of onpage, with more “normal” pages in Joomla.
I just detect another similar to the previous problem:
when the user clicks on a tag (see picture) instead of opening the new page in the same paragraph “blog” which is the user accesses the main page but not display the requested page. The user seems to not work, giving very bad effect.
Attached is a picture for you helps.
- November 2014
- 3854 times in 3563 posts
March 21, 2014 at 8:30 am #527597<em>@swissa 417323 wrote:</em><blockquote>I can’t delete anything as I don’t work here! 😉
To send a PM, simply click on Ninja Lead’s name and then select send PM.</blockquote>
For security reason, I removed credentials of your site published on the forum.
Now, I can only access FTP of your site. I need it to check the problem on your site, please pm me your site’s admin login again.
If possible, please clarify the issues again with illustration screenshot, I will help you out.
March 21, 2014 at 1:11 pm #527645I have two problems.
I now send a picture for each problem.
Problem 1
Main menu links do not work when I’m in the section that has the default template.
Problem 2
The links of the labels on the section that has the default template does not work.Sending new keys by email in a private message.
Ninja Lead
- November 2014
March 24, 2014 at 6:44 am #527784I just sent you pm, please check your inbox.
March 24, 2014 at 9:15 am #527828I read the mail. Ok.
But i answer to my two questions? I have a website about to open, and the client is nervous.
You know the answers? It is important and urgent.Thank you
March 24, 2014 at 9:51 am #527835No explanation to my problem. 1:
If I am on “Monogràfics” (url = http://elfunambul.cat/index.php?option=com_content&view=category&id=84&Itemid=518) and I returned to the onepage, there is no menu item to the main menu work, only the “Inici” (= home).
When I click on any of the items, the system adds the corresponding anchor, but not the page you requested, for example:
Item “les revistes”
http://elfunambul.cat/index.php?option=com_content&view=category&id=84&Itemid=518#les_revistesitem “el funambul”
http://elfunambul.cat/index.php?option=com_content&view=category&id=84&Itemid=518#el_funambuletc.
But the page does not move, still on the same page (“Monogràfics”).
Please give me a solution. The page should be open Friday, but only for this problem is still closed.
If you wish to continue affiliate, please help me now!
Thank you.
March 25, 2014 at 9:00 am #528015<em>@Ninja Lead 417742 wrote:</em><blockquote>I just sent you pm, please check your inbox.</blockquote>
I do not understand why I no longer responds to my questions.
The email told me yesterday that reads:
Just want to remind That your JATC Standard Membership – 3 months will be expired in 30 days (04/22/2014).
Therefore there is still almost a month to deserve their support.
I await your prompt response.
Thank you very much.
- November 2014
March 25, 2014 at 12:03 pm #528050I spent all my time today to check the problem on your site. I did help you to change all config from menu bar and template setting with module to work JA OnePage template.
Now, the problem on your site has gone out. Please check it on your site again, let me know if it helps.
March 25, 2014 at 4:40 pm #528088No, unfortunately . It does not help .
I had created a menu alternative “Menu alternatiu” with only three items ( Inici , blog , unts de venda ) , which no one noticed the problem. But now I see you’ve deleted this menu 🙁 So, the links do not work and is bad ( keep in mind that the website is now open to the public ! ) .
As it stands now continues as before I did the “Menu alternative”, In onepage main menu links work perfect. But pages are not in onepage (eg ” blog > Monogràfics “, or ” punts de venda > Condicions de compra” ) , the links do not work .
Example 1:
url
http://elfunambul.cat/2014-02-06-21-54-36/monograficsaction
Clik item the “el funàmbul”new url
http://elfunambul.cat/2014-02-06-21-54-36/monografics#el_funambulresult
The page does not move around._________________________
Example 2:
url
Clik item “les revistes”new url
http://elfunambul.cat/2014-02-06-21-54-36/monografics#les_revistesresult
There are other problems with the labels, but for now , not speak , not to complicate things .
Do you know any solution ? Forgive me , but I can not say that you have not had this problem before with this template .
I hope you can give me a light to help me 🙂
Thank you again !
Ninja Lead
- November 2014
March 26, 2014 at 10:28 am #528223My apology, I just tried to get it solved again. Please check and let me know if the issue remains at your side.
This topic contains 33 replies, has 3 voices, and was last updated by josep masso 10 years, 8 months ago.
