  • ipo_elena Friend
    #151345
    Hello!
    I’m using the JA Purity templete. I decided to have 3 columns, this is, a column on the left and the right and the main content on the middle. The problem is that the column on the right goes over the content in the middle in small monitors or when the window is being reduced, so that, the content in the middle cannot be read. I would like to have it fixed, so that if the window is small the column continues to be fixed (even if it cannot be seen entirely). Could you please help me with this?
    The web is: http://www.obs-vlfr.fr/cyber/GEOTRACES/
    Thank you very much,
    Elena
    gray Friend
    #354589
    When I visited your site in had “left-main” layout.
    Did you decide not to use the “left-main-right” layout?
    PS. From theoretical point of view in order to have re-sizable main block, its width should be set in %. But in dependence on the content inside, min. width of the main column in any case would be limited.
This topic contains 2 replies, has 2 voices, and was last updated by  gray 14 years, 2 months ago.
