February 5, 2008 at 10:50 pm #125509
I have a problem with Right side modules which are designed in Flash. It occurs only in IE in 19″ monitors. The front page looks good but when i navigate to other pages, the whole right side modules go down till the edge of the middle text. you can check the same in the attachment.
Thanks in Advance
Ramesh GK
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
February 6, 2008 at 12:58 am #238313Please check if there’s any module in right column with a big width? You coul try to unpublish all right modules and then publish one by one to figure out the one causes this problem.
February 6, 2008 at 6:39 am #238327<em>@Khanh Le 39415 wrote:</em><blockquote>Please check if there’s any module in right column with a big width? You coul try to unpublish all right modules and then publish one by one to figure out the one causes this problem.</blockquote>
Hi,I tried all these before posting it in the forum. I am not able to conclude why it is happening only for IE on 19″ monitors. Please help me. Let me know if you need anything from my side.
Thanks & Regards
Ramesh GKMarch 15, 2008 at 4:14 am #242248i have the same problem , but in 17 monitor , right colum is fine , but when i click on cb profile page , right column goes down like rameshgk site
plz can anymoderator help me ?? 🙁
March 15, 2008 at 9:42 pm #242291fixes
reduce right column width 1%AuthorPostsViewing 5 posts - 1 through 5 (of 5 total)This topic contains 5 replies, has 3 voices, and was last updated by grakz_br 16 years, 9 months ago.
Problem with Right side modules in Flash
