  • radiobib Friend
    #130967
    This is the site i am working on: http://www.oostachterhoek.nl
    In the template I set the screenwidth in index.html to ‘auto’ and that works fine in my 1900×1200 screen. But when i resize it to an approximate width of 1200 the “Lees meer” (Read on…) slides under the right sidebar (for instance try this page)
    This is not really a problem for me, but people with a 1024×768 screen resolution start to complain to me.
    How can i resolve this problem in the template? I tried the ‘narrow’ and ‘wide’ default settings without any luck.
    Rob
    1. 1024x768-frontpage
    2. 1024X768-readmore
    #260496
    Hi !
    I couldn’t load your site . Please check again !
    Menalto Friend
    #260497
    I checked,but didnt see anything specific error at that link you provied
    radiobib Friend
    #260500
    @ Hain, Menalto … you won’t see the problem until you resize your browser to 1024 wifth OR if you change your monitor settings to 1024 x 768.
    Hope that helps to clarify the problem.
    #260596
    Hi radiobib !
    I have found the problem . it is problem in html code of comment form , under the content , Please view image attactment for detail . when i use firebug to remove comment form , your site display good.
    radiobib Friend
    #260640
    Thank you Hainn84! I tried to fix it in the component, by changing the width, but without any luck. So i posted a question in this forum.
    I will post the working solution here for future JoomlaComment users.
    Rob
    #260787
    Ok radiobib !
    radiobib Friend
    #261259
    Found it! It’s a setting in Joomla!Comment component in the Layout tab > Columns number of the input area.
    I change the default from 40 to 20 and now the problem is solved.
    Sometimes life can be so easy …
    #261311
    Ok radiobib !
    I will mark this thread to “solved”.
This topic contains 9 replies, has 3 voices, and was last updated by  Sherlock 16 years, 5 months ago.
