June 27, 2012 at 11:31 pm #178579
I am having a problem with the popup not scrolling far enough to submit a comment on a K2 article. When you scroll right to the bottom you can only just see the top of the submit button and it could easily be missed. I have attached an image.How do I make the popup scroll right to the bottom so users can see the full submit button?
Any help appreciated
Mike
Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
June 29, 2012 at 10:28 am #459314Hi Mike,
It would be best to disable the capcha function.
If it not possible I will try to find another solution for you.
But it will be a trade off. The popup is a iframe, it may decrease the performance.Please pm me your site information (link/admin/ftp) so I can help you out.
AuthorPostsViewing 2 posts - 1 through 2 (of 2 total)This topic contains 2 replies, has 2 voices, and was last updated by Wall Crasher 12 years, 4 months ago.
Problem with scroll in Popup with K2 Article
