  • salvol Friend
    #169636
    If I type a word to search in the filed on the right top corner I receive the following message:
    Fatal error: Call to a member function setState() on a non-object in /home1/amiciita/public_html/modules/mod_janewspro/helpers/adapter/content.php on line 154
    If I unpublish the Janewspro module, the search function works. I am using Joomla 1.7 and Ja Teline IV
    Any suggestion, please?
    TomC Moderator
    #419145
    One way you can check as to whether it is your particular JA Newspro install is to test out the same “search” within the demo.
    You can even take it one step further and use our “Demo Builder” to set up a temporary full clone of the demo, including access to the backend administration, and test things out that way as well.
    Perhaps there may be a particular configuration issue within your particular module set-up.
This topic contains 2 replies, has 2 voices, and was last updated by  TomC 13 years ago.
